ORIGINAL: highlander52
Glad to hear it FLYMIKE.
I'm planning on a HS-6975 on the rudder and HS-635s for everything else...all at 6V. Any comments on whether the 635s will be enough? TIA
I just looked at the 635's and I take it back. I would not use them on this plane. Even if you plan to fly normal, there will be a risk of flutter in the control surfaces. If one tiny tooth on any of the gears are weak or just happen to strip on landing you will have flutter. I would fly 635's in a 40 size plane but not this one. I say this from lots of experience on this matter.
