RCU Forums - View Single Post - What size brushless motor??
Old 04-28-2007 | 11:57 AM
alienteabagger
Default RE: What size brushless motor??
ORIGINAL: Heliko
Well I just tried out my new Glo-Bee tach. I actually took my reading from the paddles with the blades removed. It's a bit safer that way. As a light source I used my led flashlight. I think it worked well because the tach zeroed out right away when pointed at the flashlight.
Anyway with [link=https://www.unitedhobbies.com/UNITEDHOBBIES/store/comersus_viewItem.asp?idProduct=3849]this[/link] motor my Axe's RPM's in a hover are 2880 and at full throttle 3120. [X(]TOOOO HIGH!!![X(]
I used DarkHorses BL calculator, but since the Axe isn't up there I'm thinking that to spite the fact I got the tooth-counts right I used the hornet set-up values so the gear circumferences were probably off. Anyway I'm going to try [link=https://www.unitedhobbies.com/UNITEDHOBBIES/store/comersus_viewItem.asp?idProduct=4875]this[/link] motor next and see what happens. I wish there was a better method other than trial and error.
Isnt a higher headspeed better (as in creating more gyroscopic effect/stability)? Now I don't mean going into insane speeds to where the parts come under undue stress from holding themselves togeher.
I hope I can get the stock pinion off the stock motor so I'll just use that.
