RCU Forums - View Single Post - Wheeeeeeee.......... Blade CP!
Old 04-28-2007 | 12:26 PM
  #2416
choppersrule
Default RE: Wheeeeeeee.......... Blade CP!
Choppersrule Here:
To all that are doing the DD tail upgrade.... It has been mentioned that the tail housing that comew with the kit is somewhat flimsie(spelling)?). I got mine yesterday(Friday) and sure enough it is flimsie.. Also, mentioned was to use the stock gearbox and modifiy it so that GWS round motor will fit..
I had a Brain Storm last night, didn't hurt at all. But here's my idea. (See pictures)
Take the original, stock gear box, using a dremel cutoff wheel, cut the part off that the tail skid slips into.. Take that piece and put it on the boom first, then the GWS gearbox. I haven't finished the installation yet, to much to do today, so the attached pitures are just for starters. But it will give you my train of thought... Gotta run.. Back later.
Dave / Choppersrule
ORIGINAL: ArrowNaughtic
Heh............. I am waiting to do mine till the current tail motor gets weaker. Mine came yesterday........ its all spread out on the work bench, but i just can't force myself to remove a working tail motor. I will get a couple more flights in today, then toss it!
ORIGINAL: Wnuk
The mailman was here today. Guess what I got from boyztoyz? Time for some upgrades!
__________________________________________________ _________________________________
Of all the things I ever lost.............................................. .... I miss my mind the most!
ID:	673916   Click image for larger version
ID:	673917   Click image for larger version
