RCU Forums - View Single Post - Wheeeeeeee.......... Blade CP!
Old 04-28-2007 | 04:45 PM
  #2423
choppersrule
Default RE: Wheeeeeeee.......... Blade CP!
Arrow,
I'm working on mine as I type, well not at the same time of course. But I was looking at the GWS gearbox, and I don't believe you'll be able to drill and mount a tail skid on it.. Doesn't look like there's room, and the plastic on the GWS box is pretty soft too.
Back to work on the heli I go.... Pictures later tonight (if i don't forget- Yuk-Yuk).
Dave / Choppersrule
__________________________________________________ __________________________________________________ ________
ORIGINAL: ArrowNaughtic
Using the CSRC 1250mah lipos, I don't think I will have to worry too much about weight. that and the battery tray from the Superskids allows me to move my battery quite a ways forward. One mod to the GWS tail mount is definately cutting off the bearing holder, and the flimsy tail fin. Then will drill a small hole in the new mount and try to install the carbon fiber tail from the stock one.......if not then I will do Daves mod, that looks pretty simple too! Ty choppersrule....excellent idea!
Of all the things I ever lost.......................................... I miss my mind the most!
