RCU Forums - View Single Post - screw hole alignment
Old 02-23-2003 | 08:35 PM
JEanes's Avatar
JEanes
Default screw hole alignment
Ever had trouble at the field seeing the holes to mount your cowling ? Use a small pc. of white covering around the holes so when you mount the cowling you can see the holes against the covering. Use darker colors against light covering.
