RCU Forums - View Single Post - HELIMAX PRO SETUP ISSUE !!
Old 04-28-2007 | 09:05 PM
Heliko's Avatar
Heliko
Default RE: HELIMAX PRO SETUP ISSUE !!
I don't have that heli, but it sounds to me like the main gear is upside down, or the one-way bearing has been installed upside down. If the maingear came with the bearing pre-installed pull the gear out, flip it over, and re-install it.
The bearing allows the rotor system to keep rotating if the motor fails or is shut off. This is what make auto-rotations possible.
