RCU Forums - View Single Post - Wheeeeeeee.......... Blade CP!
Old 04-28-2007 | 09:41 PM
  #2440
choppersrule
Default RE: Wheeeeeeee.......... Blade CP!
Wnuk,
Ouch!!!, man that's some bad luck.. My venture today installing the DD drive, was very good no problems. I've done modifications so many times, it becomes second nature to start with the basics... After DD mod was completed and a visual check, everything was okay.
I Powered everything up, set her on the floor and went through the proportional setup proceedures... Spooled up, saw which way it's going and make necessay adjustments to the proportional... Took 3 minutes or so.. fine tuning...
First flight was great,, soooo, much better than the standard Blade tail system. The weird thing is that the sound of the DD tail motor is so much different, that you think something is wrong. And it's not, just something to get use to..
Here's some pictures of the rebuild with the DD mod. Not very good pics, must have been the camera(sure)!
With my "Double Modification", as posted earlier, I used the cut off version of the tail skids, pictures will show that.. Also, I made the added tail skid about 1/4 inch longer than the DD fin.. That way, in a hurried landing, it hits the modified skid and not the DD fin.
Any questions on this, just post 'em, glad to help ya out,
Dave / Choppersrule
ORIGINAL: Wnuk
CAUTION!!!!!
This GWS tail mod is trickier then it may appear. First some stats. Stock tail assemblt is 17g. GWS Tail assembly is 24g. That's why she don't balance. So I cut my boom so I had exactly 10.5 inches from the rear of the frame to the end of the boom. I mock all the GWS stuff on, moved battery tray fully forward and with canopy on I am at a perfect CG. Ok, all looks good. Solder the wires, glue the tail motor mount, spooll it up on the bench. All looks good. Things went down hill from here.
I set it down on my smooth concrete floor and slowly began to spool it up. At about 1/4 throttle, the tail WHIPS around counterclockwise and plastic pieces fly off. Spool it back down and assess the damage. What I believe happened was the proportional and gain were up too high for the torque of this motor. Mind you I had both mine set at about mid way on the pots. When the tail whipped around, the verticle fin bent and kicked it into the prop. This caused the tips of the prop to brake off, see attached pics. No problem I said, remember those extra motor mount and prop I ordered? I can use these I think, and start with the gain and proportional turned way down. Well, I'll be darned, they sent me the WRONG spare prop. The spare is too large! Good thing I kept the stock tail assembly in tact. I have a spare boom and will install everything back to original until I get another prop.
Lessons to be learned: Start with your gain and proportional WAY DOWN when spooling up for the first time, the new tail motor has TONS of torque! The stock verticle fin is WAY too Flimsly. I think Choppers has a good idea with cutting and reusing the stock tail fin. It is much stronger then the GWS one.
Oh well; Enjoy the pics, have a laugh like I did, and then proceed with your tail mod with my experience fresh in your mind.
Arrow buddy, where are those bananas? I could use them about now!
ID:	674292   Click image for larger version
ID:	674293   Click image for larger version
ID:	674294   Click image for larger version
ID:	674295   Click image for larger version
ID:	674296   Click image for larger version
