ORIGINAL: jetnuno
I probably go with an outboard gas installation, but anyway what is the Jetcat menu where you can burn all the gas in the start-up procedure?
Regds
under LIMITs, Drain GasTank enabled. If enabled, after turbine is started and throttled up, the starting gas valve will open, draining the tank.
kc
