ORIGINAL: Pearl_414
...crashing because of low battery is another story and it's hard to stop flying cause it's so fun. I can easily understand your mishaps which I don't call crashes, just unfortunate actions...
Corey
lol, i had one of those unfortunate actions today. cost me blades, a head teardown, and straightening my flybar. well worth it.[8D]
[edit: DD=direct drive. to install a DD setup, first you remove the stock tail motor, gear, & tail rotor. then you use a dremel tool to round out the flat spot where the motor goes. next install a gws edf-50 motor with a gws 0320 direct drive prop. DD provides top level tail holding performance, especially when you have a heading hold gyro to go with it. imo DD should be a first upgrade for most ppl.]
-kev
