RCU Forums - View Single Post - FS One by Hangar 9
Old 04-29-2007 | 09:49 AM
  #977
sctholson
Default RE: FS One by Hangar 9
Hi Michael;
First, I forgot to thank you for your assistance yesterday, I was so tired I couldn't continue. Second, I have installed the 1.06 patch, downloaded the latest audio and video drivers for my hardware. Restarted the Pc and FSOne.
Still the same issue.
In the Spektrum transmitter:
Right stick for/aft works fine
Righ Stick left/right works fine
Left stick for/aft seems to control throttle and idle up
Left stick left/right works fine
The top right switch does nothing
and I noticed when calibrating the transmitter, the top right switch has no Axis, however the top left switch seems to be on Axis 3
One more note about Axis' the left stick for/aft is on Axis 2 and 4
I also rechecked for any mixing going on in the transmitter, and found none. I also reset the transmitter model number I was using to default settings.
Scott
ORIGINAL: MSelig
Scott -
If you are at version 1.0.1, then you need to get a patch to fix issues w/ calibration ... that you're experiencing. That's step one and it might solve some of the trouble which has been resolved w/ patches. So we're really backing up here from switch swapping, to basic Tx functions, to not having any patches. Patches are key here.
I think I need to start prefacing any questions with "what version are you running". This goes double for any Tx questions.
Michael
