RE: Fustrated at trying to learn how to fly on a simulator
Climbing in a turn means the plane is not banked enough. If it's banked too much, the plane will dive into the ground as you pull back on elevator. Planes also climb less in turns if you use the rudder along with the ailerons and elevator.
