RCU Forums - View Single Post - FS One by Hangar 9
Old 04-29-2007 | 11:01 AM
  #979
btamxx
Default RE: FS One by Hangar 9
Hi Scott.
For what it's worth, I have found that even the switches in the Tx. editor are assigned an Axis/Channel. If you slide the screen to the far right where you can view the servos, the REAL channels that the Tx. uses will be marked as to what servo they are wired to. You might want to try going by these channels instead of the Axis assignments. It worked for me.
Hope this helps,
Bill
ORIGINAL: sctholson
Hi Michael;
First, I forgot to thank you for your assistance yesterday, I was so tired I couldn't continue. Second, I have installed the 1.06 patch, downloaded the latest audio and video drivers for my hardware. Restarted the Pc and FSOne.
Still the same issue.
In the Spektrum transmitter:
Right stick for/aft works fine
Righ Stick left/right works fine
Left stick for/aft seems to control throttle and idle up
Left stick left/right works fine
The top right switch does nothing
and I noticed when calibrating the transmitter, the top right switch has no Axis, however the top left switch seems to be on Axis 3
One more note about Axis' the left stick for/aft is on Axis 2 and 4
I also rechecked for any mixing going on in the transmitter, and found none. I also reset the transmitter model number I was using to default settings.
Scott
ORIGINAL: MSelig
Scott -
If you are at version 1.0.1, then you need to get a patch to fix issues w/ calibration ... that you're experiencing. That's step one and it might solve some of the trouble which has been resolved w/ patches. So we're really backing up here from switch swapping, to basic Tx functions, to not having any patches. Patches are key here.
I think I need to start prefacing any questions with "what version are you running". This goes double for any Tx questions.
Michael
