ORIGINAL: sctholson
<snip>
I also reset the transmitter model number I was using to default settings.
Scott
Good to hear you're up-to-date w/ patches.
Ok, you might be resetting it to heli mode. Try doing resetting to aircraft mode. Remember we're just using the Tx as a dubby box and the computer does the heli mixing, etc. I run my Tx in aircraft mode. I just found this out. If this solves the problem, then I'll update the FAQ item.
I think if you're not seeing text on buttons, then that's a graphics card issue. Brian might have comments on this.
Michael
