RCU Forums - View Single Post - FS One by Hangar 9
Old 04-29-2007 | 12:20 PM
  #991
sctholson
Default RE: FS One by Hangar 9
Hi Michael,
Resetting the transmitter into aircraft mode was the answer. Now all functions work as you have outlined. Specifically for the main difference is the idle up switch is on the right toggle. thanks.
Life's getting better!
Scott
ORIGINAL: MSelig
ORIGINAL: sctholson
<snip>
I also reset the transmitter model number I was using to default settings.
Scott
Good to hear you're up-to-date w/ patches.
Ok, you might be resetting it to heli mode. Try doing resetting to aircraft mode. Remember we're just using the Tx as a dubby box and the computer does the heli mixing, etc. I run my Tx in aircraft mode. I just found this out. If this solves the problem, then I'll update the FAQ item.
I think if you're not seeing text on buttons, then that's a graphics card issue. Brian might have comments on this.
Michael
