RCU Forums - View Single Post - TESTED DIESEL FUELS - completed
Old 04-29-2007 | 01:41 PM
merugo
Default RE: TESTED DIESEL FUELS
MIX NUMBER: .07.................................. SUGGESTED NAME: AIR FRESH MIX ..... DATE: 04/29/2007...........
ORIGINAL REPORTER: merugo..............LAST EDITOR:..........................LAST EDIT:................
OTHER USERS:
FORMULA (in order of decreasing percentage of volume ):
1)-.40..%..Kerosene..........................
2)- 25..%..castor...............................
3)-17.5%...TURPENTINE ..(vegetal, NO mineral substitute!!)....
4)-17.5%....ether.........................
5)............%................................... .......
The way the mix it was obtained: ...straight mixing............................................ ............................................
1)ENGINE:.MARS 2.5cc...CARBURETOR: .fix.. RUN TIME: ..2h....STARTING: ..flip............. USER:merugo.......
Comments:This is basically an italian mix, fifty years old. Nice pine fragrance! It is an interesting opening to the use of terpenes for diesel. They give a strong mix witout the need of additives. IF YOU PREFER CITRUS FRAGRANCE YOU CAN SUBSTITUTE LEMONENE (tech grade) FOR THE TURPENTINE, same results!
2)ENGINE:.............CARBURETOR:.........RUN TIME: ...........STARTING:........................ .. USER:...................
Comments:......................................... ..................
Additional user observations:
Nickname :........................ Observation:
Non user comments:
Nickname : .................Comment:......................... .................................................. .......................
Nickname :................. Comment:.......................................... .................................................. .....
PURPOSE:
SHARE FORMULAS, EXPERIENCES AND SUGGESTIONS.
RULES:
EVERYONE CAN ADD HIS EXPERIENCE AND/OR BRIEF COMMENT FOR A GIVEN FORMULA by reediting and setting edition date
USE:
COPY; EDIT AND PUBLISH. NO CONTRIBUTION CAN BE MODIFIED IF NOT BY ITS AUTHOR
END
