ORIGINAL: sctholson
Hi Michael,
Resetting the transmitter into aircraft mode was the answer. Now all functions work as you have outlined. Specifically for the main difference is the idle up switch is on the right toggle. thanks.
Life's getting better!
Scott
<snip>
Good! I tweaked the FAQ so that the next person (including me) does not run into the same confusion.
To move the idle up/normal switch from the right side to the left, only requires one step (easier than what I thought before). Make a copy of the JR 6 Ch Emu setup for the Blade CP. Then edit the Tx and change the axis on the 6th channel so that it reads not the right switch (axis 2) but the left switch (axis 3). The change is indicated below. Now the idle up/normal is on the left switch when you fly.
You can do it another way (like I was thinking before), but it's more work and no better.
Michael
