ORIGINAL: MSelig
Malcolmm -
Long answer:
Does wing rock happen w/ all airplanes in real? No. Are there theories for wing rock? Sort of and they are various, and nothing is very satisfactory. Are there any specific aerodynamics models in the literature? Not that I've found math-model wise. Does FS One have any special aerodynamics model for wing rock? Yes, but we turned it off in the version you have because it's a work in progress. Do some airplanes in FS One wing rock anyway? Yes, in some situations you'll see it happen. Why do they wing rock in FS One ... "anyway"? I don't know, but it happens w/ some airplanes in some situations. Do the other sims model wing rock? No, not that I'm aware of (includes RC and full scale in the mass market and in research). How do I know? Because I've looked really hard at this. There are a zillion things in the aerodynamics in FS One, but wing rock is still a work in progress. There are others. By the way, the more aero we throw at your computer, the slower the sim. It's a trade off. Right now our sim uses (way) more CPU for aero than probably any other sim out there. Nothing in FS One is 'fudge', and we don't want to fudge what we don't know bottom to top - wing rock. When we understand the underlying mechanism for wing rock, we'll include it as a patch. Some things from what you describe make me think your Funtana90 in real was not setup as good as (or like) the one in the sim. Mike McConville setup all Hangar 9 airplanes in the sim (i.e. set the c.g., throws, and radio expos-D/R stuff).
Another idea - you might want to try turning on turbulence. Pick "Wind" and then pick "Turbulent Wind", say 10 mph. That's going to be more realistic and you'll see more, I'll say, 'rocking around'. This turbulence will slow your frame rate. I get 90 Hz w/ this turbulence at Frasca field. Press 'f' to see your framerate. It should be above 60 Hz if you have the recommended specs. Panos run much faster.
BTW - Here's a video of the real Funtana90 doing walls (easy as was mentioned above):
http://www.seligspace.com/videos/
This one:
http://www.seligspace.com/videos/Rea...lightTests.wmv
It was taken on a turbulent windy day. We use video like this to help 'tune' the airplanes in the sim. Mike was flying. I was talking. This was my first experience seeing this stuff in real / up close, and "it concerned me"....
Michael
