Terrific Michael;
I'll check out the revised FAQ. One concern that I don't really need to address now but is on my mind, is that; I was under the impression that if I wanted to I could actually use the mixes in my Spektrum transmitter instead of FSOne software. This latest "reset as if it is an airplane transmitter" issue sort of makes me think that the original idea is not an available option anymore. Is that now a correct assumption? If it is not it sounds like the result would make a good future FAQ.
Now for my other comment, since I cannot see the text fields in the transmitter editor I'm just going to try out different selections on this channel, maybe I'll get lucky!
Scott
ORIGINAL: MSelig
ORIGINAL: sctholson
Hi Michael,
Resetting the transmitter into aircraft mode was the answer. Now all functions work as you have outlined. Specifically for the main difference is the idle up switch is on the right toggle. thanks.
Life's getting better!
Scott
<snip>
Good! I tweaked the FAQ so that the next person (including me) does not run into the same confusion.
To move the idle up/normal switch from the right side to the left, only requires one step (easier than what I thought before). Make a copy of the JR 6 Ch Emu setup for the Blade CP. Then edit the Tx and change the axis on the 6th channel so that it reads not the right switch (axis 2) but the left switch (axis 3). The change is indicated below. Now the idle up/normal is on the left switch when you fly.
You can do it another way (like I was thinking before), but it's more work and no better.
Michael
