RE: WHAT IS THIS HOLE???????
The whole assembly is called an auto bailer. You might just want to purchase a new one. There should be an o ring in it first then the ball then the wire to hold it in . I would just buy a new one and use the parts in yours unless you can get the old one out and install new unit. Some times you can heat it up if it was epoxy in and pull it out.
