RE: Twinstar II Lipo Battery confusion/decisions (3s 2500-3200 ideal) thoughts?
Markm75,
This is my Bro-in-laws' plane. I'm not sure of the watts/volts... Will try to get that info. Here are a couple of pics I took for another interested noes wheel steerer. What you can't see in the pics is an extention to the steering rod. A GWS prop adapter. Also not visible is the piece of thin plywood that the steering rod also passes through. This is to support the front to back/side to side loads on the steering rod. I think the size of the ply is something like 1.5" X 2", maybe 3/32" or 1/8" thickness. It;s taken some very hard nose heavy landings and even bent so far back that the wheel made a dent in the foam.
Rick
PS; Sorry for no pics. I live in a rural area with a satallite internet connection which is a bit unreliable at times & would not upload the pics. Will try again this evening.
