RCU Forums - View Single Post - TESTED DIESEL FUELS - completed
Old 04-30-2007 | 02:13 AM
Lou Crane
Default RE: TESTED DIESEL FUELS
MIX NUMBER: .NA.................................. SUGGESTED NAME: NA..... DATE: Various, over past few years...........
ORIGINAL REPORTER: Lou Crane..............LAST EDITOR:..........................LAST EDIT:................
OTHER USERS:
FORMULA (in order of decreasing percentage of volume ):
1)- 41..%..Kerosene..........................
2)- 33%....ether ...............................
3)- 22%..castor.........................
4)- 3% Synthetic oil
5)- 1% AN ignition improver..............................
The way the mix was obtained: ...straight mixing by volume............................................ ............................................
1)ENGINE:.Various, mostly PAW...CARBURETOR: .fixed.. RUN TIME: ..Various....STARTING: ..as few as 2 flips, hot............. USER:Lou Crane.......
Comments:...This is close to factory recommended mix for well-broken-in PAW 1BB or 2BB engines. With 25% total oil, it works well in well-broken-in plain bearing PAW engines.
2)ENGINE:.............CARBURETOR:.........RUN TIME: ...........STARTING:........................ .. USER:...................
Comments: Good starting, easy setting, dependable fuels mixed from John Deere starting ether, campstove kero, SIG AA Castor and AN from Clutton (in USA). John Deere starting ether claims to be 80% high quality technical ether (diethyl?), and blends volume-adjusted for that % do well, dependably.
Additional user observations:
Nickname :None............... Observation: The high vapor pressure of the ether fraction complicates use with uniflow type tank venting in CL flying -characterized by long (up to 7+ minutes) running full-bore at optimum setting - most recent experience indicates non-uniflow tank venting works better. Diesels have ample fuel draw to live with the changes of dynamic fuel head in CL flight if tank width is kept reasonable.
Nickname :........................ Observation:
Non user comments:
Nickname : .................Comment:......................... .................................................. .......................
Nickname :................. Comment:.......................................... .................................................. .....
PURPOSE:
SHARE FORMULAS, EXPERIENCES AND SUGGESTIONS.
RULES:
EVERYONE CAN ADD HIS EXPERIENCE AND/OR BRIEF COMMENT FOR A GIVEN FORMULA by reediting and setting edition date
USE:
COPY; EDIT AND PUBLISH. NO CONTRIBUTION CAN BE MODIFIED IF NOT BY ITS AUTHOR
END
