RE: Maxair Revolution II Velox
They are still advertising them at Maxair? & OMP I think.
My Harrier situation with the Velox: After re-shaping the warped elevator half & flying again, it did not change the situation, but;...
I dialed in more spoilerons, I had to do the same thing I have in the Do, the elev-flap mix was maxed out at 100%, so I added in an open P-mix for another 35% elev-flap(135% total) & it started to lock in better even in gusty winds. When it calmed down a bit I came in low once(about 8 feet,nothing special). Its a bit more work than I expected but I think this will do it. At least on a calm day I'll be able to drag the tail. I still had to use right aileron once in a while but it was gusty so I assume it was that. I still have enough travel on the ailerons even with the 135% mix up to level the wings.
