Side Thrust Off - how to correct?
Hi.
I'm building a Venture 60 Kit (my first build). I mounted the engine mount and then build the fuselage. The fuselage is dead straight, but it looks like the piece that the engine is mounted to is angle just slightly. Therefore, the side thrust is off by a couple of degrees. The down thrust is correct.
How can I correct this? Can I place a couple of washers behind the engine mount? Or sand the mount?
