RE: axe cp thread
I wouldn't even bother doing that if I were you. The Axe is plenty stable as it is, If you want to slow down the cyclic put a wheel collar on each side of the flybar and even that is masking the real problem which is you hamfisting the sticks. Flying a heli is an excercise in constant control, Learning it right the first time will go a long ways in flying different birds because no two are going to fly the same even if there the same model.
