RCU Forums - View Single Post - Blade CX UpGrades For Beginner?
Old 04-30-2007 | 02:29 PM
DrunkYoda
Default RE: Blade CX UpGrades For Beginner?
Be prepared to break the top head, replace with aluminum,never will break again.
Also later about 3 times as long you will break the lower head, replace with aluminum,, again will never break again.
About 6 times longer, you will break the swashplate, replace with aluminum you will never break again.
Keep lots of upper and lower blades (come in upper orlower sets of 2 for about $4.
Optional
Replace tail with boom tail.
buyextra batteries... 1 don't ever fly it once it becomes hard to fly, you will ruin battery, 2 don' use batteries back to back , let the bird cool for 5 minutes between each.
Drill small holes into lexan covering on hood, helps keep the temp down.
Don't fly outside unless you move the servo arms all the way out. or at least out about 2 clicks. it will go bye bye real fast with factory servos links.
That's all.
