RCU Forums - View Single Post - Pull Starter
Thread: Pull Starter
Old 04-30-2007 | 09:34 PM
Chubbysdad
Default RE: Pull Starter
pullstarters are can be tough to get back together. Sometimes you can luck out if the spring didn't break inside.
I would run 20 percent if I were you. 30 percent will shorten the life span of your motor but you will get a bit more out of the motor while it is still running lol..
