RCU Forums - View Single Post - Large format copier accuracy?
Old 04-30-2007 | 10:19 PM
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: Large format copier accuracy?
jacobezzell,
I do the same thing with all of my plans for any kit that I'm building. What you need to do is check the accuracy of the plan right there on the spot. The people in the copy center are normally happy to work with you to get the copy right (make sure you tell them that it's got to be accurate). They can make adjustments to the machine to get the output to match the original. Also, they shouldn't charge you for copies that aren't right. It might take a little bit of time to get them done, but it's easy enough to get the machines adjusted properly.
Ken
