RE: Wing shape, drag and CG on Delta
You could increase the section thickness percentage at the centre enough to hide the tank etc and still use the 6% tip. Your tip mods will make little if any difference to the handling. Leading edge radius affects the handling the same as any wing, increasing the radius at the tip will make for a more gentle stall at low speeds even on a delta. But on one this small, how slow do you want to go?
Evan, WB#12.
