RCU Forums - View Single Post - Float Step Placement - What's going to happen?
Old 05-02-2007 | 08:41 AM
Newc
Default RE: Float Step Placement - What's going to happen?
Another important facet that hasn't been mentioned is the incidence between the wing and the floats. If you have a couple (1 - 2) degrees of positive incidence - wing angled up more than the floats - the misplacement of the step will be reduced significanlty as the plane will want to gently lift off instead of rotating aroung the step.
