RCU Forums - View Single Post - Do sizes of gloplugs make any difference?
Old 05-02-2007 | 10:51 AM
opjose's Avatar
opjose
Default RE: Do sizes of gloplugs make any difference?
Usually this is the result of a bad plug, or too rich of a mixture.
When you remove the igniter your glow plug is effectively cooling off.
Try setting the low speed needle even lower in small 1/4 increments and see if you can get it to idle this way.
If you are unsuccessful, try a hotter plug too.
