RCU Forums - View Single Post - New CDI - opensource project JMJ and Bigboat
Old 05-02-2007 | 11:39 AM
  #200
venomxx
Default RE: New CDI - opensource project JMJ and Bigboat
I saw on Ebay the other night a modded engine that has a push button start.
The motor is mounted right on the side of the flywheel. It has some sort of mods with gears. I'm wondering if anyone has done similar mod to their engines?
Push button start sounds like fun since I am using a 6channel radio. Maybe I could try to utilize all the channels for extra functions: rudder raised and lowered, perhaps a closed/open intake to cool engine head since i'm not using water cooling.
While at it I might add rocket launchers and a rottating gattling gun on the hull ~ okay that's just a dream.
Editted:
COuld someone answer the question I have about which wire to solder on the Ignition coil ?
What about using an HV transformer from a Television for a spark coil ?
Is that even possible ? Those making 10k+ volts
