RCU Forums - View Single Post - Wiring Problem!
Old 05-02-2007 | 03:18 PM
SuperCub Man
Default Wiring Problem!
I am building a twin engined bi-plane. All four wings are removable and I have a servo in each wing plus running lights in the top wing. I will have four servos in the bottom wing - two aileron and two motor. I am looking for some way to plug in the electric contacts between the fuse and the wings without cutting holes in the root ribs. Ideally I'd like to have the electrics plug in as I plug in the wing. I don't know of any plugs that could be glued in the wing and fuse that would do this. I would need to be sure the aileron plugs were securely connected for obvious reasons.
-Anyone try something like this?
-Is it a wise idea?
Appreciate your comments.
