Inline IC engines
I'm not sure if this is the right forum to post this question...
I've got 2 cox TD 09 engines wth throttle/carburetor and i'm thinking to put them inline, with a puller and a pusher prop. I've done a bit of research and the second propeller (pusher) would have a higher pitch so the incoming air can be accelerated even more.
The front pulling propeller could have more blades to get a more amount of air, say 3 blade pull prop at front and 2 blode higher pitch pusher prop at the back.
The throttles would be controlled by a single servo between the engines.
Would this setup work, or is it worth to try out of curiosity?
Thanks.
