RCU Forums - View Single Post - Cutting down APC props
Old 05-03-2007 | 11:39 AM
Rodney
Default RE: Cutting down APC props
While it might not be worth while, if you make sure the prop is balanced both statically and airodynamically (identical tip shape) there should really be no problem in cutting them down. They may not be as efficient as a commercial prop of the same size but; if there are no mechanical defects and balanced, they should be as safe to use as any other prop.
