RCU Forums - View Single Post - Blade CX2 Problem....
Old 05-03-2007 | 11:46 AM
ArrowNaughtic's Avatar
ArrowNaughtic
Default RE: Blade CX2 Problem....
Check both inner and outer shafts, they are probably bent and binding....... Also look at the flybar and make sure it is straight and tracking parralell to the upper blades......... Blade tracking should be looked at as well as swash being level. That should get ya started, post back when you have checked those things.
__________________________________________________ __________________________________
Of all the things I ever lost............................................. I miss my mind the most!
