RCU Forums - View Single Post - Difference between Turmoil RTR and Pro?
Old 05-03-2007 | 02:50 PM
Werk-It
Default RE: Difference between Turmoil RTR and Pro?
Couples more things to add off the top of my head:
Hinge pin braces and bulkeheads - They are CNC instead of cast aluminum.
Radio tray is better quality. Aluminum and design.
Radio try supports are aluminum instead of plastic.
Steering assembly bearing supported instead of bushings.
I believe the brakes are also bearings supported instead of bushings as well.
Center drives are CVD instead of dogbone.
I thinnk that's about it, although I'm sure there are a couple other differences.
HTH
