RE: Inline IC engines
The conclusions are correct.
It is not a reinforcement for the crank that you need nor the inrushing air creating problems; just a washer to take the thrust of the rear engine. As a pusher, you will get aluminum to aluminum for thrust bearing material. This is not the best combination, hence the need for a thrust washer made of steel or bronze.
