RE: Saito 1.80 Problems
This is an interesting problem. If all other items have been checked, have you pulled the rear cover and checked the bearings for wear/slack by wiggling the crank? To remove the spinner factor, run it without the spinner. Are you setting the idle needle per instructions listed many times on the Saito club?
I'd sure like to hear how this is resolved!
Dave
