RE: Echo BME twin
Looks great. Did you get any pictures of the welded crank? Was sit welded all the way around or tacked? Also noticed no bearing in front of the case or behind the prop hub. Any reason one way or the other. What carb did you use? All I have left to move to the new house and shop is the lathe and mill. Maybe I can get to mine in a while. We will see.
