RCU Forums - View Single Post - Maxx Products HD LED Switch
Old 05-04-2007 | 11:59 AM
rwright142's Avatar
rwright142
Default RE: Maxx Products HD LED Switch
Thanks. I know I need to get a voltmeter but I thought this would be a little piece of mind between checking the battery after a few flights.
Have you verified if the LEDs are calibrated correctly? By that I mean if they are fairly accurate. I will try this over the weekend by having the battery fully charged then go fly for 3 o4 4 flights, and see if the LEDs change. Then I will put it on the bench and "fly" for several more 10-15 minute flights to check the LEDs.
Thanks again.
