ORIGINAL: naynay12
Ok,but how am i suppose to center the steering trim on the radio when the servo wont woik since the arm is off?Is the arm the horn?
You center the servo.. The arm is the servo horn. The spline still spins. You just center the servo itself first, then center the wheels, THEN install the arm/horn back on. This way you both center your servo and your steering.
