RCU Forums - View Single Post - SIG Fourstar 40 (4*) Build Thread
Old 05-05-2007 | 02:02 PM
  #48
rwright142's Avatar
rwright142
Default RE: SIG Fourstar 40 (4*) Build Thread
I bought a Maxx Products HD LED Switch and drilled holes on the side of the fuselage for it. This switch is the ON/OFF switch for the receiver power and has a slot for inserting the charging cord from the transformer. That way, I won't have to remove the wing to charge the receiver battery. The switch also has 3 LEDs to quickly check the battery charge. This is only for quick visual indicator to let me know if there is a problem. I will still charge properly and also have a voltmeter that I will use to verify the charge.
ID:	678185   Click image for larger version
ID:	678186   Click image for larger version
