RCU Forums - View Single Post - Saito compression ?
Old 05-05-2007 | 04:12 PM
daveopam's Avatar
daveopam
My Feedback: (9)
Default RE: Saito compression ?
bugugly. This sound like your first four stroke. I like to pull the valve covers before the first run. I check the valve clearance and run some oil down the pushrod tubes. This will make sure the cam is lubed during the first start up. I use my after run oil which is a 50/50 mix of ATF and Marvel Mystery Oil.
David
