They give you two small washers (#3 and #4) I only used #4 and the pitch was fine...I think (maybe that is the problem I'm having with my red light comming on too early though).
I'll have to look at that but I got a house full right now so I can't work on the heli. It does sound like my head speed is quite a bit faster though but I thought it was just the gearing. The auto hub and gear is sweet though isn't it?
ORIGINAL: Oracus
ORIGINAL: crashcrash
Micro-Heli...I recieved the stainless spindle, auto hub and shaft from......HO-Chi-Min City, VIETNAM. Packaging labled "product of Canada" the parts are in.[:@]
Hey! crash
I got my MicroHeli main gear and shaft w/auto hub on Thursday evening. This thing is awesome I just finished installing it today. I got 1 question for you after you installed it did it throw your pitch out mine was about -5 to +7. I didn't check it at first it would barely lift off the ground(I thought my batt was done). So then I checked the pitch and it was out of wack(was fine before install).
