inside the cb there is a clutch that seperates when rotational pull from the engine is applied, most likely the problem is the slipper clutch is too loose so all you have to do is tighten it a bit, but not too much
ORIGINAL: chevy427
hey long island think i got tht problem can u explain how the clutch bell works my mt moves like the clutch is slipping the bell is very loose
