RCU Forums - View Single Post - Savage X fuel mix ?
Old 05-05-2007 | 07:59 PM
crazykat
Default RE: Savage X fuel mix ?
When you are taking the temperature, is the body on or off? During break in, i use some foil around the cooling head to bring up the temps in the 200's and still stay rich enough for break in. I personally don't think it is wise to run cooler temperatures under 200. I have read that you can cause excessive wear on the sleeve if it does not get up the operating temps.
