RCU Forums - View Single Post - Walkera Dragonfly #36
Old 05-05-2007 | 08:14 PM
  #7382
HeliSmith
Default RE: Walkera Dragonfly #36
There was a roomer that an autoshift RX, such as the Berg 7L would work with the Walkera TX. This is unconfirmed though. If Orion would get around to ordering a 7L, as he has came inches from doing several times, we would have our answer.
On another note.. Has anyone noticed that you can't tin coat or solder to the wires coming off of your Walkera Outrunner brushless motor. I got my Phoenix 35 today and easily soldered the bullet connectors onto it. Went to tin coat the wires on my brushless motor, because I hacked off the ends, and I couldn't get it to stick. Even tried flux! So then I just fluxed it up and stuck the wire in the bullet and got it hot and put the solder through the hole, the hole in the side of the bullet for solder. 2 of three are nice and solid, I just lost one when I went to try and start my motor. Damn damn damn! So now I have to try again.
Friggin Walkera can't even make a flippin piece of wire worth a damn!
HS
