RCU Forums - View Single Post - First Post - Locking for thread lock advice
Old 05-05-2007 | 09:19 PM
blacksheep1998
Default RE: First Post - Locking for thread lock advice
The kit should have blue and green threadlock. Green is used for seating the bearing in the metal holders, to keep outer race from spinning. The blue should be used on everything else.
I use the Blue (loctite 242) on everything and it works fine. The only one to watch out for is do not use the Red stuff, unless it is a part which never has to come apart again. Also dont use treadlock on platic parts, if you need to use CA or super glue for those. I have not had to use any kind of thread lock on the plastic screws because they are self tapping, and do not back out with vibration.
Pete
