RCU Forums - View Single Post - XTM 457 Pro Help
Old 05-06-2007 | 06:23 PM
AlucardTepes
Default RE: XTM 457 Pro Help
I took the engine out this morning and had a look at where the exhaust header meets the engine. In my opinion it was quite loose. It did not feel to me that it was making a seal of any form. Also, the purple silcone coupler from the header to the tuned pipe seemed loose to me as well. How tight of a seal should things be?
I also changed the gearing to 49t/15t. Will this be to much torque with this engine?
The transmission will need to be adjusted to shift at a higher speed.
With this gearing, will I need to make it shift later then factory setting or sooner? From 1st to second, and from second to thrid?
Thanks for all the help/suggestions so far!!
