RE: SERVO MOVES
It sounds to me like your elevator is in a bind. Disconnect the servo and check to see if the elevator moves freely through its entire range of motion without locking up. A servo that is pushing hard against a control surface that won't move will buzz and drain your reciever battery extra fast as well. It's likely that the elevator was not bevelled enough around the hinge.
